Every once in a while when I fire up the truck it will either be locked on setting 1 or 5 and wont allow me to change it until I restart the truck. Ive also had it when I started the truck settings 1,3,5 would be lit up and again it would be locked. When this has been happening the truck was shut off with it on setting 1(I haven't run any other settings due to the cold weather) Anyone have any idea whats going on?
Thanks
Tech Specialist
Common problem with the Comp - if it's still under warranty, Edge will fix or replace it - my first one did the same a few years back, Edge replaced it, no problem or charge, and the replacement has been fine...
I had the same thing. they got great customer service.
Mines has 2002 written on it. Also it came with the truck so it looks like im outta luck for any warrenty replacements. The good thing is when it is frozen I just restart the truck and it goes back to normal. Im curious as to what setting it really is on when its frozen tho.
Mine has been doing that also, and lately if you step on it hard its started throwing codes. And mine to is out of warranty so i just ordered the banks system with the pda, so hopefully that works better than my edge has been!!
