The edge does not remove or increase your speed limiter on your truck. You truck is programmed to de-fuel when you reach the factory speed limiter. The edge speed setting is only an alert and tells you when you reach the certian speed you have set it at. You need a programmer to increase your speed limiter. I have the power pup and it increases your stock speed limiter to 200mph. I have only takin my truck to 127mph. I felt that was fast enuf for a 7500+ pound lifted truck.So is 111mph the top end even with the hot unlock?
:CRY::butt::CRY::butt::CRY::butt::CRY::butt::CRY:so this is a 6.7 owner ONLY forum, i see just because i have a 5.9 i cant even say what mine does without catching feed back. you should talk to the moderators and see if they could put a lock on this forum so unless you have a 6.7 you cant even read or post a reply.
