1 - 4 of 4 Posts
I have a 1999 dodge that I have switched the engine from the original 24v to a 93 12v. The truck now has a bad ecu and I was wanting to know if one out of a gas engine truck would work in it cause I am having a little trouble finding one for a cummins engine. The reason I thought it might is where the 12v engine is all mechanical and not run by the comp. Thanks
Gas no workie! this sounds like a lot of work to get everything close to working with any ECM or PCM especially with auto trans.
you would have to switch all your gauges to mechanical gauges
1 - 4 of 4 Posts
