Question: How does the ECO System work?
Answer: Our Patented Technology works by enhancing the fuel you are currently using on your fleet or personal vehicle causing it to burn more completely in the combustion chamber. This can easily be proven by an emissions test on Gasoline vehicles to show the decrease in Harmful exhaust emissions such as Hydrocarbons (HC), Carbon Monoxide (CO) and Oxides of Nitrogen (Nox). In Diesels you will notice a substantial decrease in Particulate Matter. The more complete burn means lower emissions, increased power, less hesitation and less fuel. By the fuel burning more completely, you also have less carbon buildup, cleaner injectors and less carbon going into your oil. The ECO System test results show that the Reid Vapor Pressure (The ability of a liquid going from a liquid to a gaseous state) is improved, Gasoline: Untreated 7.6 lbs. to Treated: 8.4 lbs. Diesel Fuel: Untreated 0.6 to 1.0 Actual test reports can be seen by clicking ECO Info and double clicking Test Results.
Question: How much does the ECO System Cost?
Answer: Depending on the type vehicle and size engine ECO Systems retail from $170.00 to Just under $500.00 including the installation kit for most passenger vehicles. Installation charges normally run between $40.00 and $60.00 for most installations. Most of our distributors offer discounts for multiple orders, fleets and municipalities.
