Its great, no more bang.:thumbsup:How is it working out? never had one of those on any truck.
Its a dampener down only after market, DeeZee 02 up that's why I posted it showing it can be done on a 2nd gen with a little drilling.At first I thought you used a hood strut.
Did you have to replace the upper bolt the struts sit on?
I had no idea struts were ever added to a pickup tailgate from the factory. Does it take more effort when lifting the tailgate? In other words, is that a double acting piston or a single action?
Not at all hood struts are pressure to assist lift, these are a one way shock just the reverse.hood struts? good idea!
The hole location is the most important part of the in stall I will post theGot one for Christmas. How important is the hole location on the tailgate? Can you give me a measurement of the hole from the bolt on the tailgate in your picture? Installing it on my 96 2500.
Floyd
Take the tail light out the stud is staked in so it wont come out grind off the the end and knock it out you will need a nut.:thumbsup:OK, I've got a lot of projects going now. Just took a look at my truck and the upper mount for the cable looks like its a permanently attached. Does it unscrew with vice grips? How did you do the upper mount?
Thanks
Floyd
