I know this has been beaten to death and I've been reading for days and I've also contacted a couple others about this via PM. Anyways, I'm pretty much settled on the early pattern for my 04.5 but my question is this, It seems that everyone is worried about the spraying out of the bowl if injection timing is too advanced. I had a thought about this, what if we could put a thinner sealing washer on the bottom, effectively lowering the injector in the head and making it spray closer to the piston, effectively making it lower in the bowl so timing couold be advanced more? Would this work or are there some weird dynamics that I'm not considering? I don't think the timing would be effected because it's being sprayed in at the same time as before, it's just being sprayed a little lower. Are thinner washers even available? Any thoughts?:banghead::confused013:
If you had a 12 valve head on there you could. But these 24v require a specific height for the high pressure connectors to seal up. Best I can think of would be possibly decking the head to come up with a different nozzle height. Do some nozzles (john deere or deutz maybe) give a different height in relation to the combustion cup?
Oh ya. the connector tube. Good point graderman. I figured I was missing something.
I thought it was the opposite of what you said. If we run early 03-04 spray angle it will spray more in the bowl but a 03-04 cannot runs ours because it will always be spraying out of the bowl. A lot of guys like to run early spray angle on the late 5.9 and I felt it's since there is more play with timing and duration since its spraying towards the center more. Anyone please correct me if I'm wrong but this is what I always thought.
The 143* (03-04) spray angle actually sprays towards the radius of the wide bowl (late piston) design. The 124* spray is more in the center of the piston which creates more heat in the bowl which is one of the reasons they like to melt pistons. I'm running the 143* in my 06 and it runs very well. I have run up to 29* at 3500rpm with egts hitting 1950* at the 1/8 mile with no problems thus far. If your worried about spraying outside the bowl go with larger injectors, less duration means less timing.
