1 - 4 of 4 Posts
So i'm fed up my 48re and all its problems . Needing some help!!! i would like some information on people who have done this swap or are currently doing it..
-Overall cost / common problems?
-What to expect as far as down time and performance?
-What to do about the ECM?
-5 speed or 6 speed?
-ETC..
I just finsihed this very project. It is very straight forward procedure. You will need the following parts:
Trans(NV5600) is what i used
Motor plate (some say its not neccessary but i got it with trans so changed it
Fly wheel
clutch pack
clutch pedal
clutch hydros
Rubber boot to seal the hole u cut in floor(this was the hardest to find for me "junk yard")
the floor console(cup holders)
The leather shift boot
map pocket that replaces the auto cup holder
drive shafts lengths changed or shafts from a manual truck
trans mount plate from dodge(this is not the rubber V u get from parts house)
input shaft on transfer case changed to standard(29 spline count)
Smarty with recovery file for manual transmission from MADS
And be able to do alittle wiring for it to start and get reverse lights
To make it start cut the yellow with blue tracer and either ground it or tun to the start safety switch on clutch pedal. The reverse light you use the 2 white wires on has a grey tracer and i think the other is green. These wires are found in the 6 pin flat plug o driver side of auto.
There maybe somethings im not remembering at the moment but i think thats it. If you have any more questions fee free to ask.
Reactions: milk---man
Thank you soo much!!! an ill let you know how it goes.
Glad to help hit me up if you run into something. But, it really is not all that hard.
1 - 4 of 4 Posts
