1 - 10 of 10 Posts
I’m in the market for new tires. Currently I have 295-70r18 Toyo AT2 on method 18x9 wheels.
The new tires I’m interested in are Nitto ridge grapplers. My main question is: The 295/70 is a pretty high load 129q and the “12ply” F rated 35x12.50 is 128q...why does the 12ply have a lower load rating? Am I missing something here?
I tow pretty frequently (15k) so I want to have solid, reliable tires. I have nothing to complain about with the Toyo’s, I’m simply inquiring because I’m confused about the load ratings vs plies I guess. 35x12.50 is what I’m leaning towards.
thank you!
I'm guessing E is @ 80psi
F is @ 65 psi.
If you're towing heavy, you'll want the 80psi. Firmer.
I just went through this. The wider tires are going to be F, 12 ply 65psi.
Sent from my SM-N950U using Tapatalk
The nitto ridge grapplers are F rated @80psi...that’s why I’m confused.
Cummins Dude
Here’s a link to the specs on all Nitto’s.
From what I've seen, the newer "F" load rating is just another letter. Load index is what matters.
And yes there are similar size E & F rated tires with similar load ratings. F rated tires aren't automatically better, but maybe it's good marketing??
Reactions: Jimmy N.
So what’s a better towing tire? 295-70r18 E with 129q or the 35x12.50r18 F with a 128Q?
i believe the E is a 10 ply tire and the F is a 12. The F has stiffer sidewalls and will give a rougher ride unloaded.
I think the consensus now is the load index is the go to number for carrying capacity.
I run a 285/75-18 E. 35x11.8-18. 4080 lb capacity.
The higher the letter, the heavier the rating, period. However this is only valid when comparing the same exact size. A standard tire on my work truck is G rated, however I always spec an H rated tire , they always will give better wear.
Smaller tire = mo power towing. But not alot of difference between them 2.
Reactions: Jimmy N.
As stated e is 10 and f is 12. The load index rate how much weight it can carry. When you get start getting into wider tires (think 11”) they have to go to a f rating to be able to hold the 80psi safely. I’ve seen same size Toyos 35-12.50r20 one f and one e. The e was rated at 65 and f at 80. Not sure why width plays into to the ply rating and pressure but that is what I found out when looking.
1 - 10 of 10 Posts
