does any one kno if you have to run a inner spacer to fit 12.50's on a drw? on my 05 i have about 3/4" between leaf pack and inner tire and i dont think ill be able to fit these tires without a inner. i do have a 2" for between duals but am unsure about inner
Discussion Starter #2
anyone? ive heard use a 1/4 inner spacer but i just cant see how a 12.50 will still fit, do the perches on drw trucks have different stances for different model years?
KONG
I am running a 3/8 spacer behind my inner, then wheel, then 1.5" spacer, then wheel. 285/75/17 Dura Grappler. I dont think its needed, but the tire is very close to rubbing the inner fenderliner.
3/8 is close on a 285, so that with a 12.50 may not be enough, how much thread do u have left when the 3/8 is on the oem stud?
KONG
With the 3/8 spacer behind the inner wheel and the 1.5" spacer on the rim, its flush with the face of the 1.5" spacer. then the outer rim goes on the 1.5" spacer/studs
