Mr. Vehicle Destroyer
I think the rail feed line and fitting are larger, negating the need for the dual line (i.e. the pump can't flow more out than the line efficiently will, which is the case for the 5.9)
yes there are dual fuelers out there
Dual fueler isn't the same thing as a dual feed line (at least how I usually interpret it) Dual fueler is where you use 2 CP3's and the dual feed line is where there are two outlet fittings on 1 CP3.
Kurt is correct. A single feed line is more then enough even for 2 cp3s. I have no issues with fuel flow.
