It looks like at the end of the year we'll be getting a diesel for the farm. I've been finding deals on duelies but have no use for it. What would the cost be to swap out the drw to a srw?
Little to nothing if you could find someone to swap with.
:confused013:
I forgot to add to the above post!
I'm not understanding why you are posting on the 6.7 CAB N CHASSIS thread. This is what makes everything so confusing.....Same as all the post about programmers and delete mess, tons of input but half of them are from regular trucks!
I'm sure you will be hard pressed to find anyone in this part of CF that would have a SRW cab n chassis!
Well you are all duelie guys and I figured you guys would probably know
swap consists of removing the front spacers, swapping rear axles and swapping the bed. That's it.
And they are just saying that you posted this in the wrong section. You are in the Cab & Chassis section which usually contains trucks that were built by dodge with no bed. You would get alot better response if you posted this question in the correct forum.
