1 - 20 of 25 Posts
So here is my problem. My parking brake doesnt hold at all. my read brakes dont work at all.
I have adjusted the star-wheel in side the drums... and waaaa-laaa it fixed the parking brake and rear brakes. Well i drive the truck more than 2 miles and baammm there back out again. any ideas?
I have new shoes and new hardware spring. i just dont understand what else it could be.
P.s. my parking brake cable is tightened all the way down. (good or bad?)
well thats what i did to both sides (pull the drum) but everything is fine in side.
i did notice (inside the drum) that the star wheel touches the adjustment lever. however, when the brakes are applied it nocks the adjustment lever off the starwheel. any ideas?
thats what i thought. but i when i took it apart i noticed it was correct looking at pictures i found on the internet. does anyone have a pictures of there drum set up? so i can compare.
I adjusted then with the drum off and on as far as I could. And it worked until I drove. If can email me the pictures ill ok you my email. Thanks a ton man
Discussion Starter · #9 ·
thats a good thread. dont worry about taking pictures for me later that does it all right there. im going to edit a pictures and ill ask about it when i get it done (in a few min)
· Rescue Tower
Star wheel and arms shoud both have an L and R on them. So you know what side they go on.
Discussion Starter · #11 ·
brakes1_zps493a8c50.jpg photo by Redneckrodeo5 | Photobucket
ok so in this picture the the spring in the white is down a notch in the lower hole. (does it matter?)
the red- that lever hops off the starwheel when the brakes are applied or the ebrake it applied.
blue- the spring that incases the ebrake cable always hits the fron brake pad... is that normal?
Discussion Starter · #14 ·
has there been a upgraded lever recently? or is there a place to get a new one? other than the dealership
Discussion Starter · #18 ·
Ok we'll I'm at my wits end on these brakes. Now that I have replaced all the adjustment levers,cables,star wheel... My brakes work but not my parking brake..
A mistake many make when rebuilding is not fully releasing the parking brake cable. Make the basic adjust with the bottom adjuster and make sure the adjusting lever will adjust the shoes out when compress link.
After doing this, the park brake cable should not require hardly any adjusting. You might even forgo the parking cable adjust until you drive a bit and readjust the adjuster. This should get you well in the ball park. All bets are off if you don't assemble correctlly. By the way, the springs are good from pictures. You can tell when they bad.
Discussion Starter · #20 ·
Good write sizer. Ill try to take some pictures tommrow. But some how my adjustment lever is not staying in contact of my star wheel. It won't adjust the star wheel automatically. And if I manually adjust it... It's good until I drive and it loosens back up.
1 - 20 of 25 Posts
