Did the kit come with a drop pitman arm too?I had the pop noise too. The problem was the Pro Comp kit came with both the drop bracket and extended tack bar. You can only use one or the other not both. But the instructions showed both.
The drop bracket is used with the factory track bar.
The extended track bar installs as is and doesn't req the drop bracket since it is longer.
Hope this helps.
:agree2:I think you may be missing ban89's point. The longer track bar keeps the axle centered under the truck, but the drop track bar bracket keeps the track bar and the draglink parallel. That is very important for proper steering without bump steer and death wobble.
