1 - 9 of 9 Posts
Ok guys this stupid woman needs help. What is the easiest way to change a carrier bearing on 3500 4x4 dually? Shudder starts just before stopping and is gone before stopped completely. Checked U joints and they seem ok replaced less that a year ago. Anything else it could be?
great first post ... you get lots of help that way huh :lol3:
Maybe take it to a mechanic that knows what he's doing? good luck.
i'll bet she's referring to her self, anyhow they are difficult to change without the right tools and or equipment
:welcome: A seizing u-joint will cause that. But your carrier bearing could be at fault as well.
Dodge | Commins | Forum
Check And See If There Is Any Play At The Carrier Bearing.if The Truck Is Lifted You Might Need To Drop The Bearing.
Right on B B RAM . THAY ARE GOOD FOR SEIZED UJOINTS JUST WENT THROUGH THAT WITH MINE GOOD LUCK.
Would it help to lift the truck completely off the ground and then run through the gears and come to a stop while you or someone is looking at it. That way you might be able to see if something is wobbling like the carrier bearing or U-Joint.
Granted, if truck is lifted, make some spaces to lower the carrier bearing down. That happened on my 1st gen when I pt a 4" lift on. Fixed it right up lowering it down some.
1 - 9 of 9 Posts
