Anyone have your driverside stop and turn stop working?? Iv been working on it for hours but have no power in the turn/stop wire. And can not find a blown fuse in the box under the hood is there a second fuse box somewhere?? Its a 07 6.7 3500 drw 4 door 6 speed
Sent from my DROID RAZR using AutoGuide.com App
If you have power in the tail light but nothing in the stop & turn you might need a new bulb, it may sound stupid but a new bulb isn't nescisarily a good bulb!!! If thats not the case you may need to trace wires to look for a broken wire or connection, and make sure you check any trailer plugs, sometimes a real butcher job on a plug installation can cause alot of problems, espeacially an aftermarket plug in the bed for a fithwheel or gooseneck hitch. hope this helps!!!
