1 - 18 of 18 Posts
just curious if any of you guys out thre experienced the drivers side carpet getting wet on the floor in youre truck when it rains hard out and what you found was the problem.....any sugg???
Do you have a sunroof?(Theres a little drain that is supposed to carry the water away and sometimes leaks in, there was a TSB out I believe)
Also, check the firewall, could be a loose grommet or something allowing water in.(If youre having the problem while driving in hard rain?)
· I wanna go fast...
Just being a smarta$$. Do you have the window all the way up and does it seem to seal?
BTW fill out your sig so we can tell what we are working on.
User CP
Edit signature
You know the rest.
Don't forget to save.
no sunroof....the truck was just sitting still... id dont know that it nec happens when driving down the road....wats TSB???
Not sure other than a door seal leaking then?:confused013:
No windsheild replacement reccently? I had one that had a leak right at the bottom passenger corner and it leaked enough for a small puddle on my '97 in a good storm...
TSB= Technical service bulletin.
Discussion Starter · #9 ·
its strange why the pass side isnt wet and the drivers side is
I have the same problem but on the pass. side. I got no clue either
I had that problem on my old truck and it was from where all my wiring ran through the firewall. If you ran some stuff thought take a look around there and see if it seeps through. Good idea to be looking inside while something runs a garden hose on the windshield. Just something to check
Do you have the roof cab lights? This was a problem for some getting water leaks. Either the lens cracks or the seal goes on ot. Need to remove and silicone.
Discussion Starter · #16 ·
i will check that stuff....thanks
I just noticed mine is all wet under the rear bench. I need to look into it after I get it back from the tranny shop.
Anyway if you are the second owner someone may have mounted an amp or something under the seat. Water could be getting water in there.
1 - 18 of 18 Posts
