I'm sure the 8" short arm rides like sh!*, but the long arms ride better than stock.clock the transfer case for the front.
wait until you drive it a little, your gonna hate tgc stuff. did you get a different trac bar or use your stock one with their bracket supplied?
Yep 8" short arm. Soon to be hitting the garbage can. Playing with long arm and coil overs..flynf7, you have the 8" short arm kit right?
Use the clocking ring for the front. The rear should be fine if you have a quad cab. If you have the MC you can drop the carrier bearing further to decrease the angle.
Joe E.
Yep 8" short arm. Soon to be hitting the garbage can. Playing with long arm and coil overs..[/QUO
I love my long arm kit!
Can anybody give a staight forward answer as to what brand/where to get an indexing ring?!
you do not need to do both just the indexing ring for an 8"-9" of liftI did install a Pure Performance adjustableTrac bar. I just got off the phone with tgc and they still say that I should not have any problems. They did suggest that I clock the transfercase to reduce the vibrations in the front driveline. Should I lengthen the front drive line as well as clock the transfer case?
hummm..... cheap one? or just a reasonable price. love mine. rides better than stock.......Get the Rize indexing ring and trans drop bracket, should fix everything. It comes with a spacer that lengthens the rear by separating the trans and transfer case. Front shaft is plenty long. I have the Rize kit and it has a full 9" of lift. But I did upgrade the skocks to Billstein 5100s. Glad I went this route and not the cheaper one.
