I read that you can drill the housing so it vents both sides instead of just one. it currently only vents 3 cylinders when it opens, and can cause boost creep.
Dual k20's has posted to drill it out several times.
after looking at one, I guess you need to take to back housing off, open the wastegate and drill thru the wastegate hole into the center divider.
