once you guys do this does anyone want to send they're stockers over so i can not knock my truck down for a week if i mess it up. If all goes good i can send my stockers back, or name your price.
oh ok I thought it was the things on the end of your vp44 that your lines go intoThe connector tube is in the head between the injector and the injector lines.
Any new updates or changes???Alright fellas here is what I found out. Got the lines and connector tubes installed took the truck for a run. It does not smoke near as much as with stock lines. Idle didn't seem to change much. Fuel pressure only dropped to 14 psi @ WOT it was 13 psi @ WOT w/ stock lines. Truck tries to die when put into gear. When letting out of the throttle quickly the truck tries to die. When pulling into my driveway (slight incline) you have to put your foot on the brake and give it some throttle to keep it from dieing. I am only running 150 horse injectors so it might be better with bigger ones. Piggy bank it empty so that will be a test for a later day. I plan on putting stock lines back on with the bigger connector tubes to see if it drivable that way.
