Do I have to use a drawstraw with an Air Dog 100, or can I just connect it to my original suction tube. I do have the motor mounted lp right now, but I am about to buy a AD 100 and want to know if I need to get anything else. Thanks.
You don't have to but I would use the draw straw since you have a REAL pump now. You are only constricting the suction by using the stock setup.
I'm using the Rapture 100 connected to the stock line connections and have zero problems. Have ran the tank down to the fuel light coming on without any pressure drops. Did have a draw straw II and was looking at pressure lose at 1/4 tank.
Yea i have a airdog 100 with stock straw and works perfect never falls below 15 at wot, though i dont have sticks yet. ill have to see then but i would worry about it
I too have a ad100 with a tied into the stock canister with the OEM draw straw and I have had no problems so far. However, I do not have a FP gauge yet so I dont have a number yet.
