1 - 4 of 4 Posts
I need a supplier for a two port draw straw(return/suction). Piper Ca wrote an article, a while back, on how to install one, with pictures, but all I can find is is a single port that needs a new hole drilled in the tank.
Anyone have a supplier for the two port, replacement, style draw straw? If so, please send me an email [email protected].
I don't know of anything like that, but why are you needing it? Do you have the factory in tank pump or something? By the way, I was under the impression that net bots cruised sites like this collecting e-mail addresses for spamming/spyware purposes. I would take advantage of the PM feature. (I could be wrong!)
The factory setup without the in tank pump already has those fittings (delivery and return) and will work fine. The In tank I believe has a tank return port which prevents use of external lift pumps. You probably know all this, but just in case... Welcome, by the way!
1 - 4 of 4 Posts
