I have the Vulcan kit to remove the in tank pump. I am having high fuel pressure due to fuel not returning to the tank. Return line is hooked to what was the output side i cut the line below the tee as the instruction sad. Is there a check valve in the tee that would not let fuel return to the tank or should i cut the hose above the tee and if i do will the fuel still return to the canister and keep it full.Any one used this kit and had this problem.
