1 - 20 of 26 Posts
hey guys the dragon flow vp44 says it needs a minimum 6x.018 injector to run could i use a 7x.016 and be safe?
are you guys running the dragon flow? what would the hole size of a 250hp injector?
I know of a guy, scott, from alligator performance running a dragon flow pump, 6x16s, stock lines and tubes, his last dyno was ~650 I believe, and he daily drives it with a 64/74/14.
Discussion Starter · #12 ·
would running the smaller lines and injectors cause the pump to fail prematurely? there has to be a reason for requiring 6x.018
Discussion Starter · #13 ·
64/74/14 is tiny for the fueling capabilities, I wonder how he likes it
you can email him and ask questions, bigger is not always better though..
his email is scott AT alligatorperformance DOT com
cheers
scott only has a SOVP. he was going to put on the dragon fire but had to sell it to a customer and he didnt want to wait 2 weeks to get another one. he likes his 64 allot and i rode in it and it spools very nice. they say at least 6x16 cuz that big pump is pushing allot of fuel and if it has no where to go it will damage the pump eventualy.
Discussion Starter · #20 ·
I settled on 7x.014 with added lift they should flow the same as 6x18 hopefully
1 - 20 of 26 Posts
