What would stack well with the Dr. P2014 module. I have an 03 3500 srw with Afe stage 2, Dr. P 2014(110hp.), straight pipe and pyro/boost gauges. Stock clutch 6spd., but looking at sbc dd.
Bully dog, smarty, edge juice with attitude! just to name a few
I stacked a 2018 with the juice and it worked good, I would look at getting a rail psi gauge, dr.p is very aggressive with rp, I run over 25k at 70mph, way to much psi, just tellin ya before you kill your injectors.
thanks for the info. I think my injectors are going bad too. At a stop light/sign, the rpm's will go up about 300 rpm. I will have to let out on the clutch while still on the brake for it to go back down. Injector problem, or what????????????????
