Just how are you reading that it's going into regen? Is it from the overhead warning that your DPF is full or do you have a guage that measures EGT's and you're seeing them spike?
If you would, fill out your signature with year of truck and what mods you have. I would guess your stock and not running a programmer if your still going into regens.
BTW, before deletes, my truck's EGT's would elevate showing a regen was in progress every 150 miles or so. I live at an even higher altitude than you (nearly 9,000 feet) and I think altitude plays a part in these trucks having to go into regen more often.
Finally, if you are stock, your DPF / EGR & or EGR cooler may be close to needing cleaned or replaced.
