Hello. I own an 2008 dodge 3500 6.7 srw and want to get rid of the dpf. which kit is the would be the best to buy and what kind of tuner would i need to cancel the codes? I don't need any extra power just wouldn't want the light on the dash to be on all the time? Thanks.
i would go with the DIY for the kit and your gonna need an edge pmt or xrt to clear codes ive heard the mp-8 and epp will clear codes but im not sure on that
DPF-R's kit clears the codes w/o a programmer.
If you aint 1st..Ure LAST
wat r dpf-r's? i got the h&s kit and have codes. i didn't get a programmer thow. and just unpluged egr.
you will definitely get the CEL for unplugging the egr but you may also throw codes with the h&s kit (my buddy does) in that case you should read EGR and DPF delete kits on a budget where you will find info on the DPF differential pressure sensor fooler.... if you havent already bought the $500 DPF-D kit then you could make your own for under a hundred bucks
http://www.cumminsforum.com/forum/6-7l-powertrain/101458-egr-dpf-deletes-budget.html
