like 08greyghost i get the overhead dinging too but i currently have the pressure box plugged in with no tubes of course. when i did the DIY DPF delete i test drove it for 10 - 15 miles right after and had no issues. then the next day i started it to go to work and I had the check engine light on and then a few days later the overhead started chiming in. all the while I had a pressure fooler in (100 ohm tied to a 390 ohm). also I did not have then egr unplugged to see what codes would come up first before I did that. now 2 week and counting with the dpf gone and I checked my codes with the key trick and I get:
p2080 Exhaust gas temp sensor circuit performance- bank 1 sensor 1
p242b- Exhaust gas temp sensor circuit performance- bank 1 sensor 3
P2084- Exhaust gas temp sensor circuit performance- bank 1 sensor 2
p2000- NOX Absorber efficiency below threshold bank 1
p244a- DPF differential pressure low
p2453- Particulate pressure sensor A circuit performance
p0405- egr unplugged
currently have the factory downpipe
I have sims made with 330 ohm resistors.
Also i have the AF ECM flash or the 55351435BA ECM flash
Right now the only of clearing these codes is by the 5 times on key trick
what am i doing wrong and are any of these codes hurting my truck? any comments are greatly apprecited
thanks, Joe
