1 - 4 of 4 Posts
Banned
I am seriously trying to figure out which DPF delete system to go with that has the fooler box with it, I guess. I have my own plasma cutter, wire welder and supplies to make the delete pipe but, honestly dont know which sensor goes where. If i could buy one, which system is the BEST and most updated. Also, what is the best program to clear the codes? I plan on doing the EGR bypass as soon as I dipose of the DPF system. Thanks for any help?
It doesn't matter which one goes where. I have the early BADP module. I welded up my own exhaust. You can see my post (5" sidepipes completed).
I welded the o2 sensor and one egt probe in first, then about 12" down, I welded another o2 and egt probe,then another 18" down, I welded the last egt probe. Discarded the pressure sensors, and hooked the egt wires to the fooler.
2-3 mpg increase and no problems for the last 1000 miles!
Banned
cool. All I need now is time and money!
1 - 4 of 4 Posts
