1 - 20 of 43 Posts
Here is a few pics of my double din install using the kit from Amazon.
Discussion Starter #2
Finished Install.
I install a pioneer NEX2500 unit. It is just a millimeter to large for the faceplate kit, but still works just fine.
Instructions say to cut out the entire grey area in this pic
Cut out as per the Instructions. Die grinder wouldve been super handy. I used a plastic welder.
Note....it still didnt fit by following the I structions
Finally got for up, and decided to cut out the top area inside the radio cubby hole.
Honestly believe, ignore the instructions...and cut the top out first.
Radio kept hitting this metal piece.
Local audio shop said they cut that out to make radios for, even on newer vehicles. Which, is insane..that is a structural member.
So
.cut out the top area above the radio, radio can then tilt the 1/8" it needs to be picked up over the metal bracket.
Which also tells me, you can probably leave all the lower plastic in place
Discussion Starter #8
Up close shot of the faceplate that allows it to work.
I'm perfectly happy with how it fit the contours of the stock dash trim.
And 100x's easier than trying to plastic weld/or use bondo to allow a double din to work, like used to be done before there was this kit
doesnt look bad at all...i had a standard bezel, i would do the same. But i wont cut my wood trim bezel. if i decide to redo the door panel spears, i may paint the whole wood bezel.
I just my double din in with that kit a few days ago. I actually wrote a very opinionated e-mail/review to the company about how much more plastic actually has to be removed like the upper portion. Just glad I'm not the only one with that problem.
Yeah I have a wood bezel and don't wanna damage it :-( I would love a double din CarPlay radio though.
You don't remove as much as you would think from the overlay and it comes with a decent looking beauty ring. After a double din install, why would you ever want to go back:hehe:
Cummins lover
I recently installed the Alpine iLX-F309 in my 1998.5. There are some cons to it but overall I'm happy esp having Carplay and a big 9" screen. Side benefit is being able to use Google Maps and the satellite imagery. Carplay is worth the price and all other negatives IMO.
If I knew about this install kit ahead of time I probably would've gone that direction but the Alpine sticking out a bit doesn't bother me any. My previous radio was a Kenwood flipup and that worked OK for 10 years before it just got too outdated (Sirius radio wasn't supporting all channels available).
Can someone give me the dimensions of the opening for that double din kit? I want to get an android hu but I want to make sure it will fit inside the opening. Thanks
All double DIN should be the same size. it's a standard. There are at least 2 single DIN carplay/AA head unit, Jenson and Alpine make them. The downside is it's motorized so not sure how durable it is for off road.
https://www.crutchfield.com/g_300/All-Car-Stereos.html#&avf=Y&nvpair=FFSize|Single-DIN&nvpair=AG_iPod/iPhone Control|FFCarPlay
The android units I’m eyeing on amazon all have slightly different dimensions by a 1/4” or so
Here's my install. I think I want to pull the raio forward slightly. I also reprogrammed the start up/splash screen:grin2:
Reactions: ELY
Western WA President
Same boat...I got the wood bezel too. it's tempting to cut. That metal bit inside the dash behind the bezel wouldn't be an issue for the Sony radio I have in mind. Most of the radio fits like a single din on the top half. Screen is the only thing that takes up the 2nd din and just where the screen is.
Has anyone here used a double din radio for quadzilla gauges?
1 - 20 of 43 Posts
