I've got a 2012 6.7 with DPF delete, mini maxx and 5" TBE,Tonight after work I went for a drive into town, and I noticed something weird, when I was just cruising at about 110km/h I'd feel the truck slow, and I hadn't taken my foot off the throttle, and I looked and my boost had just dropped and then it would kick back to what it was at. Road was flat. Then I noticed I was set on cruise control at 110kmh, and I was holding 10psi, on a flat road. Also, when getting under load it's nothing for it to hit 20-27psi plus. Is there something wrong? I just run it on street, and never hard on it. In my setting it says "mild w/turbo" I think that's the aggressive tuning, is that what's going on here? Any help would be great.
I don't run the aggressive turbo tune on mine, I could never keep it under 30 psi around town haha. It's normal for the vgt to run 10 pounds down the highway, however I haven't had it cut out like you mention. It does drop down to 0 psi goin down a hill or somthing but not on flat ground. Any chances you hit the cruise switches? How often does it do this?
Sent from AutoGuide.com App
Decoder Ring Specialist
Even without the ATT mine hits 30+ in a heartbeat. Stock intact tuning had them 26-28PSI at full song so 27 isn't anything outside of its normal. I don't like seeing mine over 32-34 and so don't let it get up there.
This morning I was on my way to work, and my coolant was at 120 degrees, and I was just tippy toeing down the road to work and I hit a small hill at about 5psi, and the boost just dropped, then kicked back in. Why is it doing that?!?!? 2012 6.7
Mine does the same since the MM install DPF delete and EGR still plugged in. On another thread someone suggested unplugging the EGR valve on top cooler but I haven't had a chance to try that yet.
It's probably still cycling/blending EGR in during warm-up. H&S definitely doesn't 100% have a handle on all the stuff that goes on during warm-up...not really their fault, have to remember, they don't exactly get any help from Cummins on this stuff.
