1 - 11 of 11 Posts
Just curious but does anyone's plastic ring around the ignition key illuminate? It looks like it should. :confused013:
if I remember correctly, pull the 2 plastic covers off the steering wheel column, and you will see the ring and where the light bulb is
· Mopar1973Man.Com
Depends on the model of the truck. Like my 1996 Dodge Ram has the clear plastic ring that lights up and on my 2002 Dodge Ram its a black plastic ring that doesn't light up. I would say its part of the high line package of the center timer.
Interesting..... I removed the plastic covers off the column years ago to see if the bulb was burnt out and to my surprise there was no bulb. I dont think there was any anything in there relating to a bulb.
Mine has it as well. It is kinda nice since I leave for work at 10:00 p.m.
I think the wire is there in most trucks, but not all have the bit in the column. ther eis a timer for it in the forward side of the in cab fuse box, silver , taller, and narrower than the blinker doodads, and it gets pretty warm. My truck didn't have it, but I put in an older lower miles column, and it worked.
1 - 11 of 11 Posts
