Hi all, i have a non working speedo and i tested the tranny vss and it is supposedly good(at least good enough to get a flicker out of the speedo) i do not have any movement out of my speedo even when key is first turned on. i also have tested the rear sensor on the diff and according to the autozone diagnostic charts here http://www.autozone.com/az/cds/en_us/0900823d/80/0f/f9/18/0900823d800ff918/repairInfoPages.htm
it says to ohm's test the rear sensor and if its over 2500 ohm's replace it, there is another one that says if it is under 1000 ohm's replace it as well, mine falls in right in the middle at 1800 or so.
i dont know where to start on this problem, i am just testing everything i can considering dodge fsm's throw parts at stuff long before actually figuring out what things are
:lol3:
