is it auto or standard?
check an see if it is a 53 block?
what are they asking for it?
Its an auto, i have no clue what a 53 block is. 16,900. I read theres an HO 5.9, did it only come with a manual? Thanks
As far as mods go he'd probably just install a cai and a tuner, would the tranny hold for that? Yes i let him know that the price is high, and its cloth. He has a 08 f-250 but theres been so many recalls hes worried about what happens when the warranty runs out and what not. here's the link to it http://apps.dealerconnection.com/dealers/friendlyfords/used-inventory?_flowExecutionKey=_c8A32D7A1-3EF5-D377-5369-72AAFF67B4CA_k0D445EDF-0D4F-A548-325F-CBFA9D38C889&_eventId_requestquote=true&requestType=quote&vin=3B7KF23641G757435&dealerPACode=05017&certifiedPreownedImg=falsethe autos are not very good stock. so if he wants to add power then plan on upgrading the tranny. an for a good one your looking 4000+.
53 block is the motor that tends to crack. very few 01's have it but it is something to look for.
IMO that price is a little high. should be around 15000. is it cloth or leather inside?
Yes the HOs only came with a 6spd, although I've heard some where that when they came out some where made with 5spd.... but I dont know how true that is. The SOs came with 5spd or autos. The SO make a little more power once you start modding them. The autos from the fractory kinda suck, but if they are serviced well they last a little longer. I've read that a good service tranny with light-medium duty will last 100-140k before needing rebuild. I bought mine used with 150k and the tranny was going out, I did a shift kit and got another 45k out of it before it bit the dust. The 47RE is a great design once you set it up right and use good parts.
Just like the rest of VP44 trucks (98.5-02) they are very sensitive to fuel supply. The trucks come with a weak/crappy electric lift pump that when it goes out it usaully takes out a $1200 injection pump. So what most do is replace the stock lift pump with a reliable fuel system like AirDog or Fass as well as fuel pressure gauge or low pressure warning light.
Once you address these couple issue the trucks are great and will last a long time, well I should say the truck will fall apart around the motor before the motor is done.
Is that hwy or city? Yeah his f-250 now gets like 11-12 maybe 16 hwyif you take your time you can find much better deals. my truck is an 01 auto and its virtually flawless and had about 100k. i paid 10k for it. there around it just takes a little research. if you find one for the same price as mine u can take the other 6k and throw that into some good mods. i generally get over 20 on mine and just under it with a heavy foot
So the fuel system on the older rams is an issue?:cbadge2: cummins all the way. i bought my 2000 24v for 11k with 104,000 miles on it. its an overall good truck but ive had ALOT of problems with it. my ENTIRE fuel system wwent out, so it was $1100 for a new vp44 an $520 for an airdog 150 fuel system to replace my stock fuel pump. than it was about $350 to get an entire front brake job done (rotors, calipers, and break pads) and than it was around $400 to get both the front hub assemblies replaced, so far its cost me almost 3 grand to keep it on the road, but other than that i cant complain.
yea, the more miles you put on em the weaker the VP44 gets, and if you dont change the fuel filter on your stock pump every 3-4000 miles that could be a problem, i just so happened to buy mine at the wrong time and that time was when ALOT of things went wrong. but then again, i know alot of 2nd gen. owners that they still have the stock fuel system after 200k miles or more. depends on the year and what the truck was used forSo the fuel system on the older rams is an issue?
So then he shoud be looking for a 4th gen, any serious issues there?yea, the more miles you put on em the weaker the VP44 gets, and if you dont change the fuel filter on your stock pump every 3-4000 miles that could be a problem, i just so happened to buy mine at the wrong time and that time was when ALOT of things went wrong. but then again, i know alot of 2nd gen. owners that they still have the stock fuel system after 200k miles or more. depends on the year and what the truck was used for
get a 3rd gen from 03-07. 07.5 and on are all the 6.7 emission crap engines. i suggest the 5.9 common rail, and the 2010 dodges are just straight up ugly anyway. idk of and serious issues with the 3rd gens, cuz i havent owned one yet. lol. my next truck is a 5.9 common rail for sureSo then he shoud be looking for a 4th gen, any serious issues there?
Thanks, what about your mods, how do you like your K&N cai, notice any difference in fuel mileage or power?Congrats on the truck. You made the right choice not getting the other one. I got mine for only 10K and it's in perfect shape. You won't be sorry with the 2005 trucks. They are awesome. All you have to do is search for those key words and you'll get hundreds of hits on the forum about tuners and such.
