I found this and thought it might help someone.
A first generation Dodge Diesel truck's fuel gauge sending unit is no longer available from Mopar or aftermarket sources. The original part number is 52017992. I've found a Mopar sending unit that can be used in place of the original part with just a small modification.
Reactions: 702 3500
The comments on that video (which was posted February 2019) show that the Dodge Dakota sending unit is also discontinued. It looks like it would work if you can find one.
At a minimum this gives a larger junkyard part search option. If a junk dakota is found the sending unit in it might fix your ram.
Interesting info given that I had a guy replace mine a couple months ago. Harness plugged in but I'm getting low fuel light all the time.
It was a new part from local parts house. I'll ask where he got it then go and see what it is he actually installed.
