NEED TO KNOW SOM BASE LINE FOR EGTS ,SO I KNOW WHAT TO LOOK FOR[ COMMON EVERY DAY DRIGING STOCK 55MPH TO 75MPH? HOW MUCH IS TO MUCH? FOR HOW LONG CAN I HOLD A HIGH TEMP? WHAT SHOULD I LOOK FOR WHEN I LOAD SOME HIGH END SMARTY? NEED ALL THE INFO I CAN GET ON EGTS ,THANKS:thumbsup[/LEFT]
Go for Broke
for any length of time stay under 1250
short runs some guys see 2000+.....i have seen 1600+ on mine before the twins....now i see1300 on a WOT run
cruz'n i run around 700-800 on the hwy
I try to not stay long above 1200/1300. Probably a little conservative. Performance rigs aside, properly driven, a well tuned truck even under load should stay below 1200. If not, you either have too much fuel or not enough turbo.
For reference, pure iron melts at 1500 degrees.
One thing to remember about EGT's, the higher they are, the more fuel you are burning. When empty, if you keep your EGT's below 650-700, boost below 5 and speed below 65, you'll get much better fuel mileage.
Good info.
So Far Whith The Set Up Im Runing It Just Bumped 1000 Once Or Twice On The Highway 70mph 600to 800 Depends If Its Boosting More Or Not
Thats Fine. I ve got a buddy that pulls a 40 ft gooseneck with a fiberglass pool on it from FL to Ohio. He ran 1000* - 1100* all day no issues.
avatar challenged
I haul those big fiberglass pools too and i run 1000*-1200* unless its hilly then i can climb to 1200*-1400* but only on long steady hills. I run 65-70 mph though, slow down and they cool off quite a bit.
@ 65mph empty I am running 550-600* @ 1-2 psi.
As was said earlier....you can run 1200* all day long with no issues.....short bursts of 15-20 seconds above that are OK.......but try not too let them sit there too long
