ok, maybe not...
quick questions:
my fuel guage is only accturate to a half a tank then it is no longer accurate. where should i check first?
second problem is, my truck gets good and warm blowing from the heater just fine. but my temp. guage never gets very high? it gets up to the first line soemtimes, and sometimes just barely moves at all, never reads int he middle at all. what could be causing this and how do i fix it?
THANKSSSSSS!!!!:popcorn::popcorn::$:
check the wiring and the sending unit on your fuel gauge, i had the same problem in my 98.5
Yes, they do suck, but they're functional, so they don't suck that bad.
its a 91.5 i think? right? its a 91 with an intercooler.
Check to see if you have a thermostat installed. It's an easy job and the seal is a rubber o-ring, not a gasket.
The engine runs better at normal operating temperature.
its prob your sending unit.....so common on the dodges
even common for a bad temp. sending unit?
