1 - 11 of 11 Posts
besides dually rear ends what is the difference in trucks? ive owned a 3/4 ton but never a 1 ton and i might buy this 91 single axle 1 ton. is it just a heavier leaf pack in the rear? thanks!:butt:
1 ton had clearance lights on the cab on duallies. (Not on 1 ton single wheel)
Front and rear axles are supposed to be different with the 1 ton axles rated for more load. Springs and shocks are differant #s. (There are 7 spring choices for 1990 alone)
If it is a dually, the hubs front and rear are changed from the 3/4 ton.
i'm pretty sure the steering gear is the same, the brakes are different.
I had a single rear wheel 1 ton before I got my 3/4 ton.
i found a 91 350 auto for sale that i want to get. the odo is stopped at 212k. it has a rebuilt head which makes me thing when the bottom end will go.
Remove the oil filler cap when the engine is running to check for any blow-by. If clear and the auto trans shifts smooth with no slip then it should be okay if the price is reasonable. These engines are pretty tough if well maintained.
I looked at one a while back that was smoking like a chimney out the oil filler neck and I told them 'no thanks'. They were telling me 'they all do that' but there should not be any blow-by getting past the rings if the oil was changed on time.
I've seen lots of diesels do that and they all have ra a long time. Most will have some blow by, but if it looks like your exhaust when you stand on it, thats bad!
I wouldn't say no just because of blow by, but if it had other "issues" then it would be a turnoff.
DS79
yeah they will all have some
I asked the dealer what the difference was between 3/4T and 1T. He said mostly brakes. Has heavier brakes to stop a heavier load.
DS79
This one was pretty bad IMO. It only had 170,000 miles. I have seen cummins with much higher miles with no noticeable blow-by.
There are lots of these trucks out there if you look on e-bay or autotrader. Why not get one with less wear on the engine?
You are right, though. The engine is going to run fine even with blow-by. Not a reason to get rid of a truck.
Discussion Starter · #11 ·
i went and drove the truck last night. it runs well but i forgot to check for blow by, i was tired. got there at 8pm and had worked from 5am to 4pm that day with lack of sleep the night before!
anyways its a non intercooled 91 1 ton with e-range pirreli scorpion A/t tires. yeah the brakes do look bigger. the current owner got it from the original owner and he put isspro gauges, fuel pin, pump turned up. it already had a straight pipe. its got dual battery set up. he put h4 lights which work GREAT! it pulled 17-18psi of boost when i floored it, trans feels just like my other cummins (good). needs the kingpins rebuild but it doesnt hop. its a LE too. i think im going to buy this one. i found a 90 with about 160k but she wants more then is in my budget and she wont come down.
1 - 11 of 11 Posts
