1 - 11 of 11 Posts
05 Dodge Cummins
s/n 55G796499
Won't start unless use ether. No power but idles well. Changed lift pump, no difference. Stumped.
injection pump?
Cycle the key from off to stand by three times and see if you get any code....
Dumb question but, did you change your filter?
TECH SPECIALIST
sounds like a high pressure pump issue i would check for codes by cycling the key like stated above
DON'T EVER USE ETHER NEVER NEVER EVER
ya i agree never use either it washes the oil out of the turbo. check the turbo as well to see if its locking down. or has a great amount of shaft play if not then the cp3 pump may be going.
Tech Specialist
last truck i repaired at the dealership had a bad injector - injector had excessive return - also ran into a truck which had a pressure relief valve leaking - hope this helps
1 - 11 of 11 Posts
