First off how much diesel do you have? Mine did the same thing and it had 1/8 of a tank i put a fuel pump on it and it turned out to be out of diesel. Pull the line off of the fuel filter coming from the fuel pump turn the key on, see if you have fuel If you do then check your outlet line on the fuel filter side to check the fuel filter. If there is no fuel comin out of the pump and you have plenty of diesel Disconnect the 2 prong plug on the fuel pump power. Take a test light have someone turn the key on. Does it light up? if so and you have no fuel at all coming out of the pump its the pump. 179 at orielly's for an improved aftermarket oem replacement.. Just make sure you have plenty of diesel mine runs out at 1/8 of a tank now like i said. Hope this helps let us know!
-Jeremy:thumbsup
