· Super Moderator
If it's a 4x4 you have to have the same size tires on the front and rear. A 215 tire you'd get lousy mileage, look on the sticker on your door it will give the correct tire size.
Reactions: Antonm
Looking for tires, 97 dodge 3500. Some of the charts are shown the fronts were 215/85/16 and the rears were 235/85/16. Is that correct?
Really, rear tires that are over an inch taller than the fronts? I guess it'd work on a 2wd (might look funky though), but that'd be real bad idea on 4x4.
No, stock tires on a '97 2WD duelly were 215/85R16 load range D. Obviously a 4WD would have the same size front and rear.
Reactions: Cseybert
No different sizes front to rear, must have done later. As with most Dodges there 2 or 3 different sizes and styles available on most models. Variances from ST , SLT and Laramie too.
Some individuals have put bigger or wider tires on.
