1 - 9 of 9 Posts
What did those of you that run Detroit Lockers do with the Tone Ring for the anti-lock brake? I want to install a Detroit Locker and have been told in the past that is wasn't possible because of the tone ring. However, I know several of you are running them so I know it is possible. It may be a very simple answer once the axle is open, but I want to be prepared ahead of time. Thanks!
If I remember correctly, you take the tone ring and the Detroit to a machine shop and have them machine the step for the tone ring into the Detroit carrier.
Sent from my SM-G950U using Tapatalk
Or just delete the abs? Mine has been disabled since I’ve owned the truck and no issues even on snow/ice. All you have to do is drop the glovebox door and unplug the little black box.
Or just get the right part number and bolt it together. That's what i did on my d250.
Happen to still have that part number?
Eaton's part number is 225SL107D. Just looked at JEGS website and they have the same number. Their picture shows the step for the tone ring. Thanks guys!
Thanks! I got the 32 spline. This is perfect
1 - 9 of 9 Posts
