1 - 9 of 9 Posts
I have used Denny T's on other truks I have had with GOOD results. This latest rig I put it in and it seems I have lost some power and LESS smoke. I wanted more power and more coal out the back! But for some reason not this time.
Have any of you had a less power come when you put in your fuel pin???
that would be a first ??? esp if your not getting more smoke????
You must have put it in right if your not rollin coal!!!!
Reactions: thechoochlyman
If you put the uncut side toward the front, you aren't getting enough fuel. The cut side needs to be toward the front. If that's not the problem then it might be your fuel pump not pushing enough fuel for the demand.
yea i suppose someone could make that mistake idk though
The pin that rides on the Denny T is probably stuck.
may be you need to adjust smoke screw down a little & also check the fuel rack pin
1 - 9 of 9 Posts
