1 - 11 of 11 Posts
Has anyone run the upgraded delivery valves that are located inside your p pump? Just wondering if it was worth the time to change the valves...you know if it gave that much more?:confused013:
I think there is a point that you do have to change them. I run a set of 181`s and i love them.
I think its worth the time.
depends on which valve you are putting in. 181's have supported 800hp. I really like my 191's. IMO fullcuts are junk unless you are spraying or are moveing ALOT of air. there hot and smokey. theres a guy on here that layed down like 660hp with 131's.
I am thinking about .022s, because everyone says full cuts are bad
I got a buddy with all the same stuff as you, except he has 191s and 3k gsk , and it dynoed 400hp with an SuperB. It is smokey and kinda hot, so Id def go with at least a 62 if you want big dvs.
My bad I was looking at the wrong sig lol
What DV's are in a stock 180 pump?
1 - 11 of 11 Posts
