2001 24v cummins. Extended cab short bed SLT Laramie 172k miles, stock except level and tires
I have a 01 5.9 24v with 176k miles, and like 2 months ago the sending unit on top of the tank and stock lift pump went out. So brought it to the shop and they put a full fass system, new sending unit, and new TP sensor on. ( TP sensor was acting up for a while.) Got it back about a month ago and the truck was running perfectly but I was only building a max of 10 psi of boost. figured out one of the boots wasn't all the way on. so tightened it back up and the same day put a wicked wheel in the turbo. ( i have a boost elbow from quadzilla on it.) and like 2 days later I really started to notice it, (may have been before). But it took the truck just a little longer to start like half a second to a second longer. sometimes starts pretty much normally other times a half second other times a second longer. I have no codes on dash plugged it into the code reader, still nothing. but when I turn the key on it says fuel pressure is zero. When I crank the truck up it has 15-17 as normal. but I have no loss of power nothing. I don't think it's my VP-44 but I have no idea what. it's not hard starting either just delayed kinda
