1 - 10 of 10 Posts
So when you pull a mini maxx out of a truck it defaults to no power ?...
does anyone know if there is a possibility to program or swap filenames on the sd card so it views the "no power"tune as the "hot damn"tune??
just a thought...?so that it would default to a good tune ;D
Reactions: RWH
subscribed
Interesting. That would be nice so I could remove my mini when I'm not towing...
Very interesting but I'd rather swap it with the mild tune if possbile :)
Yea so it will default to a decent tune so your not stuck with no power in case of failure or you just want it removed from the truck
Ya know
This is the first thing I plan to do when I get MCC, my plan is to set it to wild which is what I run on then I can have an audio alert for defuels but it won't cut the fuel and throw the timing threw the roof.
On H&S's form they said it can be done.
I remember looking at the files on the SD card and they all had really cryptic names. If the files were named mild, wild, hot I can see how renaming them might get the job done but it might be hard to tell what the actual files are the way it is.
I wonder what H&S says?
I wouldn't mind running mild all the time and keeping the MM locked up in a safe somewhere with all these EPA problems.
I believe the tune stays on the tune you last had in the truck when you take it out unless you return to stock..
1 - 10 of 10 Posts
