Seriously, you just keep on worrying about your beer supply.More important things to worry about like running out of beer while changing fuel filters and no other vechile to drive to the beer store for 30 minutes…seriously.
Thats way more likely to be an issue than the baldwin filters…. These trucks are not that delicateSeriously, you just keep on worrying about your beer supply.
so let me get this straight… Rock solid fuel systems??? then it’s ok if we buy discount filters and junk fuel?Thats way more likely to be an issue than the baldwin filters…. These trucks are not that delicate
Don't get your knickers in a twist kiddo Baldwin is a quality filter.so let me get this straight… Rock solid fuel systems??? then it’s ok if we buy discount filters and junk fuel?
The post has been answered they cant get the filters as things are still hard to get so they have to get something for the customersRead my post. Trying to get opinions on why the mopar dealership would use non mopar parts. Not a kiddo.
if I could delete this entire post I would.
sorry that’s bullshit. They can get them.The post has been answered they cant get the filters as things are still hard to get so they have to get something for the customers
When they are on backorder no they cant. And they are on and off back order very often they are hard to get…. You are delusional….sorry that’s bullshit. They can get them.
I changed fuel filters in a friends 2018 2500 yesterday. First change not done at dealer. I recommended he stay with mopar filters. I was surprised to find baldwin filters in both front and back. Would it be normal for a Chrysler dealership doing service work to use something other than mopar? I checked filtration specs on front filter, <4 is what they listed, but the mopar is 3 microns I’m pretty sure.
Would use of Baldwin cause issues with warranty?
Should I take this as an endorsement for Baldwin filters or a warning about this particular dealership, which has a sketchy reputation in our area?
FASS is junk but okSingle best thing I did was to delete the factory filter and install a FASS system. Super clean fuel with super easy filter changes.
Why would you call it junk? Pumps run forever and if you don’t like their filters you can run Cat filters on it.FASS is junk but ok
The pumps fail often then take weeks to get replacements at times and the filters are not as good as OEM same with the CAT filters.Why would you call it junk? Pumps run forever and if you don’t like their filters you can run Cat filters on it.
Are you a moderator here?When they are on backorder no they cant. And they are on and off back order very often they are hard to get…. You are delusional….
Why would that matter?Are you a moderator here?
My pump never failed and it’s guaranteed for life. Filters from FASS I have now are 2 micron plus they remove all water and air from fuel. If you put water in it the pump will stall that’s how water tight it is. No factory filter I know of is that good?The pumps fail often then take weeks to get replacements at times and the filters are not as good as OEM same with the CAT filters.
unless you need the extra fuel OEM pump is the longer lasting pump.
They are not 2 micron thats been proven false many times and the OEM front filter is a true 2 microns with the nanonet for the 19+.My pump never failed and it’s guaranteed for life. Filters from FASS I have now are 2 micron plus they remove all water and air from fuel. If you put water in it the pump will stall that’s how water tight it is. No factory filter I know of is that good?
If that’s true it’s the first I heard of this. Mine is 13 years old and still going. I will have to buy a spare or something else. What did you put on?They are not 2 micron thats been proven false many times and the OEM front filter is a true 2 microns with the nanonet for the 19+.
I have had FASS before on my 05 it was terrible i went through a few pumps and it took a week at a time to get replacements many others have had the same experience. I threw my fass out and put a different setup on it
I made my own fuel setup with a holley black pumpIf that’s true it’s the first I heard of this. Mine is 13 years old and still going. I will have to buy a spare or something else. What did you put on?
Lol!!Single best thing I did was to delete the factory filter and install a FASS system. Super clean fuel with super easy filter changes.
