1 - 2 of 2 Posts
I tried a search on the error code section but for some reson my computer wont bring up the links. Anyway, yesterday truck started fine and warmed up for 20 minutes or so, I loaded up the family and started down the road....it hesitated and then just died, now she just turns over and over. Hooked up the scanner and got a p0230 code "Fuel pump primary circuit malfunction". Does this mean my lift pump is dead?. Assuming it is the lift pump that died, is my VP44 not far behind then?. Thanks for any help fellas. PS. my trucks a 2000, 5-speed All stock.
this is a electrical fault code. Wiring to LP may be damaged or pump may be dead. Check pressure with bump start method. Bump start and leave key on. Pump should run 25 seconds with 7 psi minimum and prefer 10 psi.
1 - 2 of 2 Posts
