You only need to get access to the fuel tank if you are installing or removing different fuel lines and/or pick ups. The bed can be lifted as an alternative to dropping the tank to gain access.
One problem that arises from dropping the tank is that the tank bottom can be pushed up resulting in the pick up being installed too high which causes the dreaded "1/4 or 1/2 tank" issue. A remedy is a sump or getting the pick up located correctly.
