1 - 20 of 23 Posts
I bought a set of nozzles for my 05 Ram . I wanted to change them out myself . I read the directions they have on line I think I can do but first wanted to get input from others who have done it to find out what problems I could run into. Do I need to buy the miller injector puller or can I pry them out with regular tools? Is #6 hard to get to and more difficult . I was reading my manual and it said cleanliness was important how do I keep everything clean in the process so I don't plug up the filters in the injectors? Any input would be appreciated thanks
Nope, you don't need the Miller tools, or at least I didn't. The injectors and connector tubes all popped right out. #6 is harder to reach, but I had no trouble there either. And yes, keep everything clean.
Thank's for the reply
What kinda of performance did you get out of these tips? I have been curious if its worth the money or not. What other supporting mods did you have to run? Thanks
Joe E.
Joe E.
W/ the DDP 50hp tips. It's good w/ a stock turbo and stock otherwise.
TECH SPECIALIST
What is considered a stage II ddp tip? I just ordered some 110's from lenny... Can't wait.. Talked to him for quite a while... Heck of a good guy.. How do you like your stage II's???
Shane
I haven't got them installed yet, but when I do I will let you know the results. I am hoping to pick up the 2 mpg they say I should.I am on a crazy quest to see how fuel efficient I can make this truck. Where I live you can't give a diesel away right now , so I really want to keep the truck cause I'm stuck with it anyway, so I am going to try to make the best of it .So far with my mods and using half of a bottle of power service cetane boost with each tank the best I have gotten is 24.86 mpg. That is hand calculated , I have an ST model and it does not have a lie-o -meter on it, or overhead .This is all highway driving at 55-60 mph keeping my rpms between 1700 and 1850. I am seriously thinking about a gear vendors overdrive for my next mod since all my driving is on the highway empty. I am going to try to install the tips myself since I want to learn how to work on the truck myself and have a chrysler shop manual to go with it. I just wanted to make sure I did not have to spend$143.00 for the injector puller unless I really needed it .I would like to hear what tools worke d for the guys who have done it themselves? The tube puller was only $10.90 so I purchased it.I will post result when I get done and I hope they will all be positive thank's
Shane
The stage II are 90hp. They work very well. :thumbsup
TECH SPECIALIST
I will be installing a set of F1's shortly. We'll see how they are as well.
Keep me posted... I wanted F1's but I could not find any replacement sticks to buy and send in I can't have my truck down for 3-5 days... So I went with ddp. I don't think you can go wrong either way i just need my truck...
What kinda green backs are yall throwin on these things? And will it help any with injector failure like some of the stocker have when you have a chiped truck?
Joe E.
Is that the down time for F-1, i have a feeling i am going to need a set of of sticks soon as i have been having a rough idle in the mornings the last couple of days along with the blue smoke, it only does it for about 5 minutes then quits, and runs great but it just don't seem right? Are the F-1's worth the wait compared to getting DDP's and still having the truck to drive? How much would a used pair od sticks cost? Sorry to hi-jack the thread i just thought it might fit in here!:thumbsup
Thanks guys chad
Keep us posted on how the install and the performance of the DDp im going to do the same shortly:thumbsup
do you have to replace the tubes everytime you take them out
thats what someone told me idk
wes
Thanks guys chad
You send in your ejectors to Don for inspection before he installs the new tips. If any are bad or in need of repair. He charges $150 per ejector (I believe) to repair them (the bodies).
That's what stands out w/ Don's tips (Flux tips). He inspects them, fix it and his tips are rated/tested at 39,000 psi so you can use pressure boxes w/o carnage.
awsome thats what i like to hear
1 - 20 of 23 Posts
