1 - 20 of 22 Posts
Does anybody have any expeirnce with the 50 hp ddp injectors. My milage is not worth a darn
Before I did some upgrades- I have a Bullydog Tripledog programmer and strait pipe. I would get consistant 17-18.5 mpg. Then my injectors went out.
My setup now is- 50hp ddp, AFE stage 2, Bullydog Tripledog programmer, and airdog 150. and Im getting 13.5-15 at best. It doesnt matter were my programmer is at, it doesnt seem to smoke excessively.
Just wondering if anybody has had similiar issues.
Thanks
I have heard nothing but good things about the 50hp DDPs, mileage and power are good.
When you replaced them did you replace all of them, just the nozzles?
Have you checked the oil for fuel?
I havent had any signs of fuel in the oil, I sent in a oil sample and it didnt have any signs of ether. I havent had any low rail pressure codes. I didnt put new jumper tubes in when i installed them so i want to do a return test.
When I put my air dog on I was having really high lift pressure I had to put the lightest spring in and drill my return T-fitting in the tank filler neck to get my lift pump pressure down to 18psi. Could the CP3 be back feeding fuel some how.
Any chance your just enjoying the 50 extra hp? (not trying to be a smart-arse)
Not sure on the feedback from the CP3... Seems odd at the pressure thou, did AD help you troubleshoot?
Sorry didnt reply yeah I called them and they said that they have had issues with the return fittings they have now are to small so I had to punch out the fuel dirrector flap thingy lol in the return t in the fuel filler neck. But its been a couple months since ive talked to u and Ive had to replace my tranny and Im still only getting 14 at best I have tried all kinds of cruising speeds and it doesnt seem to help. Im running a bully dog triple pup and the milage doesnt seem to change much on any setting. Ive checked to make sure that nothing in the drive line is locking up.
have u checked mileage with out the bully dog( actually pulling the program out)?
I have DDp 50's with a 62 on 35's and get 17, highway, city, lease roads.
love them.
i get 13 mpg as well with my ddp 90s stock, smarty tnt, smarty revo, bullydog dont matter never changes much lol
I get 19 on the highway, pen and paper.:thumbsup: I love my DDP's but even with a 62/71 they can still get my pyro up to ~1,500 with the TST on.
Yeah, mine runs hot to. I don't know how people run bigger than 50's with a 62.
Discussion Starter · #13 ·
Acyually no I havent I have just tried running it on stock and it didnt help much at all. But Ill try it. Ive heard that some common rails the forth injection is a injection to cool the egt is that true and would mine have that
I'm 99.9% sure there is no fourth injection.
I'm also 90% sure the third injection event is to raise EGT's to keep catoletic (SP???) convertors and dpf's cleaned out
If you have a 04.5+ you will have the third injection (so I'm told)
Reactions: Ronbob
I know 2 people with 62 that get moderate EGT's with 90's.. One of them has an aftermarket intercooler and water/meth on a SPS 62 and the other is running industrial's silver bullet. (62/74 I believe?)
I had a set of 75's for awhile (a little more than I wanted) EGT's were high if I was pushing it.
Never saw any drop in MPG, 12-13 towing, 15-17 combind daily driving. Got 19 once on a trip to FL.....70 MPH constant....Yes it was hand calculated on 2 tanks....Haven't seen anything close since, cause I'm always pulling the horse trailer.
Discussion Starter · #18 ·
ok ill try taking the tuner off and see what I get. But on the third injection I was told that the smarty turns that off which u think would help on milage maybe.
What would be a good set of injectors for my truck with the mods I have.
i just put new 90hp injectors in a few days ago. runs much smoother and i have another 90hp :thumbsup:
got them from Industrial Injection
and i easily get in the 20s for fuel milage
1 - 20 of 22 Posts
